KB81997
Published: March 26, 2013
Revision: 5.0
Controller sync of Time/Date may cause reset
Problem was discovered in version: R9.1a
Synchronization of the date or time of a controller by two or more sources at the same time may cause the controller to reset. Time synchronization sources can come from PAC Display, PAC Terminal, PAC Control Debug mode, or charts with commands that set the time and date. Any combination of two or more of these sources can cause this problem.
The commands in a strategy that can cause this problem are the Set commands in the Time/Date Group:
- Set Date
- Set Day
- Set Hours
- Set Minutes
- Set Month
- Set Seconds
- Set Time
- Set Time Zone Configuration
- Set Year
To work around this problem, use PAC Manager to inspect a control engine and set the time and date. From PAC Manager, select Tools > Inspect > System > Date and Time to make the changes.
