KB82001
Published: January 16, 2013
'Move Numeric Table to I/O Unit' may cause controller reset
Problem was discovered in version: R9.1a
If an I/O unit has any digital points, has any standard density analog points (one and two point analog modules), and the Move Numeric Table to I/O Unit PAC Control command is used with the I/O unit, the controller may reset.
