KB82016
Published: January 16, 2013
SNAP-AITM-4i displays intermittent or continual QNAN data
Problem was discovered in version: R9.1a
Resolution is included beginning in version: B9.2c
A SNAP-AITM-4i module may continually reset when plugged into a rack with a SNAP PAC brain. A QNAN (-qnan, #QNAN) error code is reported to software applications such as PAC Manager or PAC Control in Debug mode.
Another symptom can be seen from the module's Times Discovered parameter (Tools > Inspect, Status Read) in PAC Manager. This count is by default, incremented at a rate of 3.5 seconds.
