KB82046
Published: March 27, 2013
Using a literal string for URL with HTTP POST or HTTP GET commands may cause reset
SOFTPAC
Problem was introduced in version: R9.1a
Problem is fixed in version: R9.3b
Using a literal string for the URL in the PAC Control commands HTTP Get, HTTP Post Calculate Content Length, and HTTP Post from String Table may cause a controller to reset.
The image below shows an example of how the problem is caused:
Use a string variable instead of a string literal for the URL in the commands.
