KB82108
Published: December 20, 2012
No response from B3000-B after receiving invalid command
Problem was discovered in version: R3.5
Problem is fixed in version: R3.6
If a message with the wrong syntax is sent to a B3000-B that is configured for ASCII mode with Checksum (256) or CRC16, then the brain may cease responding to any current and subsequent messages. The SERIAL LED briefly flickers RED (receiving messages), but does not flicker GREEN (Transmitting messages) in response to the received messages.
