KB82124
Published: November 1, 2012
Cannot 'Listen for Incoming Communication' on same port for both UDP and TCP sessions
Problem was introduced in version: R8.0a
Problem is fixed in version: R9.3b
If the Listen for Incoming Communication command is used to listen to both TCP and UDP communication on the same port, then only the first session is valid. The second session returns error -17 Port already locked.
Example:
Suppose ch1 = "tcp:22004" and ch2 = "udp:22004",
If this code is run:
result1 = Listen for Incoming Communication( ch1 );
result2 = Listen for Incoming Communication( ch2 );
then result1 will be 0 and result2 will be -17.
