KB82145
Published: April 1, 2013
'Open Outgoing Communication' command ignores some user-specified timeout values
Problem was discovered in version: R9.2c
Problem is fixed in version: R9.3b
The timeout in PAC Control for an incoming or outgoing stream is ignored. The default values are used instead.
Examples:
Incoming stream:
SendCommunicationHandleCommand("tcp:set.to.open.i:<seconds>", COMM_Y);
Outgoing stream:
SendCommunicationHandleCommand("tcp:set.to.open.o:<seconds>", COMM_Y);
