KB82147
Published: January 16, 2013
'Enable/Disable I/O Unit Causing Current Error' may cause bus error
Problem was discovered in version: R9.1a
If the Enable I/O Unit Causing Current Error or the Disable I/O Unit Causing Current Error command is used when there is no error in the controller error queue, then a -16 Bus error message may be reported by the controller.
