KB82155
Published: July 12, 2012
False I/O Communication Failure
Problem was discovered in version: R9.2c
Problem is fixed in version: R9.2d
If a PAC Display project is configured to access the I/O directly from the I/O units, it is possible that when a window with I/O point tags is opened in Runtime, most or all of tags display the configured Comm. failure color.
No messages appear in the Event Log to indicate a problem occurred, and if OptoOPCServer is available, the Quality appears as Good, even though there was a communication failure.
If this problem occurs, then PAC Display Runtime must be restarted.
