KB82158
Published: November 21, 2012
OptoOPCServer fails after adding new tags
OptoOPCServer
Problem was discovered in version: R9.2b
Problem is fixed in version: R9.3a
OptoOPCServer may fail if there are several I/O units in a project and all but one are turned off, and the computer on which the Server is running is set to Gateway address 0.0.0.0.
The problem is presented after adding or activating a new set of OPC tags for scanning. Clients can report the following:
- PAC Display Runtime - Reports Scanner Failure to the Event Log
- OptoOPCServer Client - Reports Server Failure
