KB82167
Published: January 16, 2013
Some analog/digital commands ignore disabled point state
Problem was discovered in version: R9.2a
Problem is fixed in version: R9.2c
If communication to an output point is disabled (such as with Disable Communication to Point), all commands should not affect the point's output state. However, the following commands incorrectly affect the state of the output:
  • Start On-Pulse
  • Start Off-Pulse
  • Write String/String Table to I/O Memory Map
  • Write Number/Numeric Table to I/O Memory Map
  • Generate N Pulses
  • Ramp Analog Output
  • Start Continuous Squarewave
  • Write Point Name
