KB82244
Published: January 16, 2013
SNAP PAC Sim may transmit or display unexpected 32 or 64-bit values
Problem was discovered in version: R9.0a
SNAP PAC Sim may transmit or display unexpected 32 and 64 bit values. The byte order of the value may be reversed (big-endian or little-endian). As an example, a 32-bit decimal value of 100 is 0x00000064 but could be transmitted as 0x64000000, which is 1677721600 decimal.
