KB82274
Published: November 20, 2012
Blank Data Source Name (DSN) drop-down list
Problem was discovered in version: R9.2c
Problem is fixed in version: R9.3a
The Data Source Name (DSN), drop-down list box does not display configured datasources.
The following steps reproduce the problem:
- Create a Data Source. (In Windows XP or Windows 7-32bit Operating Systems: Use Control Panel > Administrative Tools > Data Sources(ODBC). In Windows 7 -64 bit Operating Systems: Execute c:\Windows\SysWOW64\odbcad32.exe)
- Start OptoDataLink and create a new link.
- Set the and goes to field to Database.
- Select Data Source Name.
- The Data Source Name drop-down list box is empty. It should display a list of configured data sources.
