KB82305
Published: November 20, 2012
The 'Tab' key moves through the OptoDataLink dialog backwards
OptoDataLink
Problem was discovered in version: R9.2b
Problem is fixed in version: R9.3a
In OptoDataLink, if the Tab key is used to move from field to field, the field focus movement is backwards. The focus moves from the bottom of the dialog to the top.
