KB82362
Published: November 20, 2012
Incorrect or missing messages if an OptoDataLink database connection fails
OptoDataLink
Problem was discovered in version: R9.2c
Problem is fixed in version: R9.3a
If a data link is associated with a database (in the configuration fields: Data comes from a, or and goes to a, or depending on), and the database name and user login information are left blank, a "Connection Successful!" dialog incorrectly appears after pressing the Test button. If the data link is run, no data is inserted in the database and no error is added to the error log.
