KB82389
Published: November 21, 2012
Imported Windows with grouped objects not assigned selected control engine
Problem was discovered in version: R9.2e
Problem is fixed in version: R9.3a
If a window with grouped objects is imported into PAC Display Configurator (Window > Import Window), then the control engine assigned to the imported window (by the Choose Imported Window Control Engines dialog) is not assigned to grouped objects.
This results in grouped object tags which are not updated or are updated by the wrong control engine.
