KB82402
Published: November 21, 2012
Modbus Calculator Register address is incorrect
Problem was discovered in version: R9.2e
Problem is fixed in version: R9.3a
The Modbus Calculator available from PAC Manager, always reports the Register Address as 1 more than the actual value.
Example:
Mem map address F02A000C Modbus Calculator says this would be Unit ID 23 and Register Address 7. However, the correct address is 6.
