KB82418
Published: November 21, 2012
Text changes to Button graphic label are not saved
Problem was discovered in version: R9.2d
Problem is fixed in version: R9.3a
Text that is added or changed on a Button graphic label in PAC Display Configurator, might not be saved when closing the window or the project.
To duplicate the problem:
1. Open an existing project that already has a configured strategy.
2. Select a button graphic to edit the label text.
3. Close the window.
4. Open the window. The text changes to the button label are not saved.
