KB82434
Published: November 21, 2012
Some windows may be off-screen after switching from multiple monitors to a single monitor
Problem was discovered in version: R9.2e
Problem is fixed in version: R9.3a
It is possible to work on PAC Display projects using two monitors. However, after going back to working on projects using only one monitor, it is possible for some of the dialog windows to not be displayed on the single monitor.
The dialog windows that may be affected are:
  • Alarm Points
  • Application Managers
  • Control Engines
  • Historic Logs
  • Event Log Viewer
  • Sounds
  • Window Managers
Opto 22 has resolved this issue. A button has been added (View > Reset Dialog Positions) to have the dialogs be displayed in the middle of the active display window.
