KB82439
Published: April 1, 2013
Controller does not enable G4D32RS I/O units
Problem was discovered in version: R9.2c
Problem is fixed in version: R9.3b
Control engine firmware version R9.2c does not enable G4D32RS I/O units. After communication attempts from the control engine to the I/O unit, the following messages are posted to the control engine message queue:
-539 I/O error; performing retry.
-534 Attempt(s) to communicate to I/O Unit failed.
-1 Undefined command.
Use control engine firmware version R9.2a to communicate to G4D32RS I/O units.
