KB82450
Published: October 8, 2013
Opto iPAC on iOS6: screen is cropped and unresponsive
Problem was discovered in version: Opto iPAC 1.05
Problem is fixed in version: Opto iPAC 1.1
When using an iPad with iOS6, if you launch Opto iPAC in landscape mode, all buttons are unresponsive and the sides of the screen are cropped off.
The issue affects iPad 1, 2, 3, and 4. Other iOS devices are not affected.
Zooming to 1x and then back to 2x will generally correct the problem.
This issue has been fixed in Opto iPAC version 1.1, available on the App Store.
