KB82463
Published: April 1, 2013
'Move Numeric Table to I/O Unit' may not set all output points correctly
Problem was discovered in version: R9.2c
Problem is fixed in version: R9.3b
When using the Move Numeric Table to I/O Unit command, only some of the output points may be set correctly. This command handles four types of output points in the following order of priority:
  • High density analog
  • Standard density analog
  • High density digital
  • Standard density digital
If all of the output points were of one type, then all output points are set as expected. If there were two or more types of output points, only the highest priority outputs are set correctly.
