KB82464
Published: April 1, 2013
Cannot enable I/O Unit and error -93 appears in queue
SNAP PAC Sim
Problem was discovered in version: R9.2c
Problem is fixed in version: R9.3a for SNAP PAC Sim R9.3b for all other controllers
In PAC Control Configure mode, if any digital point has Enable communication unchecked, then the I/O unit cannot be enabled. Error -93 appears in the control engine message queue when the strategy is run.
To reproduce this problem, create a digital point or change an existing digital point, and uncheck Enable communication. When the strategy is run, the blue INFO field appears at the bottom of the Debug mode window and error -93 code appears in the controller message queue. Attempts to manually enable the I/O unit fail.
