KB82476
Published: December 18, 2012
The 'depending on' Database value not always detected
OptoDataLink
Problem was discovered in version: R9.2b
Problem is fixed in version: R9.3a
If the depending on field is set to Database, OptoDataLink may not detect that the database table value is set to true (non-zero).
