KB82531
Published: January 17, 2014
Quadlet writes to the memory map of SoftPAC may fail
SOFTPAC
Problem was discovered in version: 9.3a
Problem is fixed in version: 9.3b
If you send a Write Quadlet OptoMMP command to write to a four-byte location in SoftPAC's memory map (such as the PUC flag), the write may fail. This issue can occur when using PAC Manager or other custom software. It will not occur when using a PAC Control strategy to write to the memory map, because PAC controllers always use a Write Block OptoMMP command.
