KB82600
Published: December 21, 2012
Rotating a graphic may incorrectly display a scaling message
Problem was discovered in version: R9.3a
In Configurator, if a graphic is rotated and then deselected by clicking the mouse in a blank area on the window, then the following message may appear:
"The selected rotated graphic type may not currently be scaled." The message should only appear if a graphic is scaled.
The graphic objects that are affected by this problem are:
- Lines
- Ellipses
- Rectangles
- Rounded Rectangles
- Bitmaps
