KB82614
Published: August 17, 2016
"Undefined Command" error when downloading strategy with double quotation mark ( " ) in string variable
PAC Control Basic
PAC Control Professional
Versions affected: All
If you initialize a string variable with a double quotation mark ( " ) —which is a character that the Initial Value field shouldn't allow—PAC Control displays an "Undefined Command" error message when the strategy is downloaded.
Instead, while you are still in Configuration Mode, PAC Control should warn you not to use that character in the Initial Value field.
Remove any double quotation marks from the string variable.
