KB82618
Published: October 8, 2013
aPAC app can't change E1 digital output
E1
Problem was discovered in version: R1.1a
In the Opto aPAC app, when you turn on a point on an E1 brain board, the button does not change from "Turn On" to "Turn Off", so you cannot turn the point off in the aPAC app.
Opto 22 is working on this issue and will include the fix in an upcoming release.
