KB82635
Published: February 6, 2013
One time trigger in OptoDataLink continues to record data
OptoDataLink
Problem was discovered in version: R9.3a
Problem is fixed in version: R9.3c
If OptoDataLink is configured to record data one time based on a trigger, it will continue to record data based on the Interval set in Monitoring interval in milliseconds, even though One data exchange when the value is true is checked. The problem occurs if the when Interval is not configured.
