KB82660
Published: October 30, 2015
SNAP-SCM-PROFI Profibus module may reset when connected to a device that continuously transmits data
SNAP-SCM-PROFI
Problem affects firmware: SerModProfi_MCF5249_01_00_02_01.eio
Problem is fixed in firmware:  SerModProfi_MCF5249_01_01_02_00.eio
The SNAP-SCM-PROFI module run-light occasionally goes off, and the module stops communicating. This reset happens approximately 1 to 10 seconds after the communication cable is plugged into the module, if the cable is connected to a device that is continuously sending data to the module.
