KB82662
Published: April 1, 2013
PID loop 'Enable Communication' option does not work correctly
SOFTPAC
Problem was discovered in version: R8.0a
Problem is fixed in version: R9.3b
If the Enable Communication checkbox on the Edit PID Loop window is unchecked for a PID, communication from the controller to the PID should not be enabled when the strategy is run. However, communication from the controller to the PID is enabled when the strategy is run.
