KB82676
Published: February 4, 2013
Modbus Calculator Error in PAC Manager
Problem was discovered in version: R9.3a
The PAC Manager Modbus calculator (Tools > Modbus Calculator) does not convert the memory map address for point 0 on module 0. The address is F080 0000 and PAC Manager displays the error message "Conversion Not Performed - invalid input."
Also, attempts to convert any valid Modbus Unit ID and Modbus Address 0 to a memory map address produces the error "Invalid Input! 1<=Register Address <= 65536", even though this is a valid combination. Valid register addresses are 0-65535 and the corresponding register numbers are 1-65536. Register numbers start at 1 and the corresponding register addresses start at 0.
