KB82682
Published: July 29, 2013
Pulse commands may stop working
SNAP-PAC-EB1
SNAP-PAC-EB1
SNAP-PAC-EB1-W
SNAP-PAC-EB2-W
SNAP-PAC-SB1
SNAP-PAC-SB2
G4D32EB2
Problem was introduced in version: R8.5a
Problem is fixed in version: R9.3c
A pulse command may eventually stop working. The command does not work again until the brain is rebooted.
This problem occurs more frequently if the pulse command is used with a point that is:
- Added to a Watch Window.
- Installed on a rack with analog modules.
- Frequently written to by multiple charts.
The affected pulsing commands are:
- Generate N Pulses
- Start On-Pulse
- Start Off-Pulse
- Start Continuous Square Wave
- Set TPO Period
- Set TPO Percent
