KB82778
Published: October 8, 2013
Revision: 1,0
LED-SPCV-LV100W Optomux Protocol PUC error
LED-SPCV-LV100W
Problem was discovered in version: Network LED Dimmer Firmware 3
Problem is fixed in version: Network LED Dimmer Firmware 4
After power-up or power failure with the Network LED Dimmer configured
for Optomux Protocol, the Dimmer will not execute any commands until it
receives a Powerup Clear (PUC) command. This behavior is contrary to
normal Optomux behavior as documented in the Optomux Protocol Guide,
Form 1572.
If a PUC error is returned, send a PUC command before sending other commands.
This issue is resolved in Network LED Dimmer firmware 4. To obtain new firmware, contact Opto 22 Product Support.
