KB82824
Published: October 23, 2014
Alarm point configuration may not always show digital input points
Problem was discovered in version: R9.1a
Problem is fixed in version: R9.6e
If you configure an alarm point to be set up by discrete and select a digital input point and then configure the notification option to also be set up by discrete and select a digital output point, then if you go back to the alarm point configuration to change the digital input point selection, it may no longer show the list of digital input points.
