KB82866
Published: October 15, 2014
Transmit Pointer Table command posts -29 error for persistent string
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SOFTPAC
Problem affects versions: Firmware R9.3b and lower
Problem is fixed in version: Firmware R9.3c
In PAC Control, if the Transmit Pointer Table command is passed to a pointer table with an element that points to a persistent string, a -29 (Wrong Object Type) error is returned and posted to the error queue.
Avoid putting pointers to persistent strings in a pointer table that will be transmitted.
