KB82904
Published: December 2, 2015
OptoDataLink intermittently stops recording data
OptoDataLink
Problem was discovered in version: R9.3c
Problem is fixed in version: R9.3d
OptoDataLink intermittently stops recording data when using a database as the destination. When the symptom occurs, if the user clicks the Stop button to stop the links, OptoDataLink will not respond. Data recording may spontaneously recover hours later. The issue affects all databases and is not limited to SQL type databases.
