KB82957
Published: September 9, 2014
PID loop output data destination incorrect if digital TPO point is used
EtherNet/IP Configuration Software
Problem affects versions: R3.0i and lower
Problem is fixed in version: R3.0j
In the EtherNet/IP Configurator, when a digital output point is configured for TPO and then a PID loop is configured to use that point as its Output Data Destination, the pulsing configuration area is incorrectly changed to modify the Period of the TPO instead of the Percent of the TPO.
