KB83003
Published: December 10, 2013
PAC Manager two-point analog calibration doesn't work with all points on some modules
PAC Manager
Problem affects versions: PAC Manager 9.3b and lower
Problem is fixed in version: PAC Manager 9.3c and PAC Project 9.3003
The two-point calibration method in PAC Manager is not supported above four points on a SNAP analog module. For example, on a SNAP-AITM-8 thermocouple module, which has eight points, only the first four points on the module can be calibrated using this method.
