KB83008
Published: October 16, 2014
Controller may reset under special circumstances
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
Problem affects versions: Firmware R9.2a, R9.2b, R9.3b
Problem is fixed in version: Firmware R9.3c
When the controller is set to auto run, under some circumstances the controller may reset.
If the STAT LED doesn't turn green almost immediately after it lights up amber, the reset will occur within just a few seconds. If the STAT LED turns green, the strategy will run without a problem.
Place a short delay in Block 0 of the Powerup chart.
