KB83032
Published: December 2, 2015
Button graphics with dynamic text may not display correctly in PAC Display Runtime
Problem was discovered in version: R9.3b
Problem is fixed in version: R9.3c
If a button object has the Text In From Control Engine attribute applied, the text may remain as #### in Runtime. This may also cause other Text In From Control Engine attributes on the same window to not display values and remain as ####.
