KB83046
Published: October 11, 2013
PAC Display Runtime - Multiple Simultaneous trigger-based Recipe Downloads may fail
Problem was discovered in version: R9.3b
Problem is fixed in version: R9.3c
If a project is configured with multiple trigger-based recipe downloads triggered off the same trigger, all the downloads will be triggered simultaneously and some may fail. Messages in the event log may indicate that the recipe file is invalid or show error 0Xc00400c (duplicate group name on OPC server).
Use separate triggers for each recipe.
