KB83047
Published: October 16, 2014
SoftPAC: Send Communication Handle Command returns "not implemented" error with RMDIR
SOFTPAC
Problem affects versions: Firmware R9.3b and lower
Problem is fixed in version: Firmware R9.3c
In PAC Control on a SoftPAC controller, if you are using the Send Communication Handle Command and include the RMDIR command on an FTP handle, a "Not Implemented" (-36) error will be returned.
