KB83075
Published: October 28, 2013
SuperTrend pen configuration dialog shows incorrect Max or Min Value
Problem was discovered in version: R9.3b
Problem is fixed in version: R9.3c
When configuring a SuperTrend pen the maximum and minimum range values are not retained. After you configure the range values for a pen and then return to the pen's configuration dialog box the range values may have changed.
