KB83135
Published: July 30, 2013
OptoOPCServer crashes when using OPC 1.0 interface
OptoOPCServer
Applies to all versions up to & including: R9.3a
OptoOPCServer crashes when you are using the OPC 1.0 interface. Most customers use the OPC 2.0 interface, which is the default.
The crash error message may look similar to this:
OptoOPC.exe - Application Error
X The instruction at "0x7c9108d3" referenced memory at "0xfffffff8". The memory could not be "read".
Click OK to terminate the program.
Use the OPC 2.0 interface if possible.
Or
contact Product Support for beta version B9.3b (9.3.1.1) dated 7/8/2013 (or newer). Use the beta version following these instructions:
- Close PAC Display and all OPC clients.
- Close OptoOPCServer.
- Browse to the OptoCOM folder.
- On Windows XP, it will be at:
C:\Windows\System32\OptoCOM\
- On 64-bit versions of Windows, it will be at: C:\Windows\SysWOW64\OptoCom\
4. Replace the existing version of OptoOPC.exe with the beta version.
