KB83162
Published: April 18, 2014
Server SSL certificates are not verified by control engine
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SNAP-PAC-S1-FM
Versions affected: R9.2c through R9.3c
Problem is fixed in version: R9.3e
When using one of the following PAC Control commands, if an SSL certificate is not present or is signed by an untrusted certificate authority, the communication can still succeed without error.
- SendEmail
- SendEmailWithAttachments
- HttpGet
- HttpPostFromStringTable
If the certificate is not present or valid, the communication should fail and error code -2104 should be returned in the Put Status In argument.
