KB83163
Published: August 11, 2014
SNAP PAC controller or brain continuously resets after saving large user files to flash
SNAP-PAC-S1-FM
SNAP-PAC-R1-FM
SNAP-PAC-R2-FM
SNAP-PAC-EB1
SNAP-PAC-EB1-FM
SNAP-PAC-EB1-W
SNAP-PAC-EB2
SNAP-PAC-EB2-FM
SNAP-PAC-EB2-W
SNAP-PAC-SB1
SNAP-PAC-SB2
G4EB2
OPTOEMU-SNR-3V
OPTOEMU-SNR-DR1
OPTOEMU-SNR-DR2
Problem affects versions: Firmware R9.1a to R9.3c
Problem is fixed in version: Firmware R9.3e
If the files stored in the user flash file storage area take up a lot of room, the SNAP PAC controller or brain may continuously reset after you save your files to flash using PAC Manager.
To recover from a resetting device, either Restore to Factory Defaults or use Failsafe Bootloader mode to load a firmware version that is not affected by this issue.
