KB83171
Published: October 29, 2013
PAC Display Configurator Basic generates incorrect scanner tag names for IO points on serial brains
Problem was discovered in version: R9.2b
PAC Display Configurator Basic generates incorrect scanner tag names for IO Points on Serial brains. For example, if you have an SB2 attached to an R2 with an analog input point on the SB2, PAC Display should create a CONT tag in order to get the value via the controller. Instead it might incorrectly generate an MMIO tag to get the value directly.
