KB83172
Published: August 30, 2013
AsyncRead of tables or strings causes OptoOPCServer to crash when using the OPC 1.0 interface
OptoOPCServer
Problem was discovered in version: R9.3a
Problem is fixed in version: R9.3b
When using the OPC 1.0 interface, doing an AsyncRead of tables or strings will cause the OptoOPCServer to crash.
If possible use the OPC 2.0 interface for communications.
