KB83187
Published: October 29, 2013
Sending repeated values from PID control does not work in PAC Display Runtime
Problem was discovered in version: R9.2b
Problem is fixed in version: R9.3c
Only the initial write of a PID value from the PID dialog succeeds. For example, if a PID control is showing and the Setpoint is changed, the write only succeeds the first time. Subsequent attempts to change the setpoint or any other value will fail.
